2008 JKUR Rear Wheel Chirp/Squeak
Old May 28, 2024 | 05:12 AM
MD_JKUR3.eight's Avatar
Default 2008 JKUR Rear Wheel Chirp/Squeak
Driving into work this morning with the top off and I noticed I have a pretty bad rotational chirp/squeak coming from the rear, my ear says right rear wheel, definitely speed dependent, seemed to go away/lessen while coasting in neutral/with the clutch depressed and also while braking.
Mostly wondering if there's a likely culprit...do the wheel bearings get noisy in this fashion when they need replaced? Maybe brake/caliper dragging? Debating if I need to run it to a local shop before I head home today or if it can wait
Old May 28, 2024 | 07:56 AM
resharp001's Avatar
Loved
Community Favorite
The most common issue is a bent flange on a rear axle shaft.
Old May 28, 2024 | 08:40 AM
That was my first guess, a little perplexed why it goes away when I am coasting in neutral/clutch in though going away while braking makes sense....I'll get it up on a jack tonight when I get home and see if there's any obvious signs of a wobble.
Old Jun 5, 2024 | 01:11 PM
MountainTrails88's Avatar
5 Year Member
Loved
Community Favorite
Squeaking noise is usually shocks. And the chirp could be the brakes.
