2011 jk trans cooler
Old Nov 25, 2010 | 06:54 PM
myz28u's Avatar
Default 2011 jk trans cooler
I've been reading the horror stories of jku auto trans meltdowns. In one thread someone stated the 2011 model should not have this problem. Is this true or am I gonna be looking at the same issues as the older jk owners.
If there was a fix in the 2011 model year what was it. If not then do I need to be concerned or should I just let warranty take care of it the install a cooler.
Old Nov 25, 2010 | 10:33 PM
JKlad's Avatar
Unless they start fitting seperate aux trans oil coolers to JKs at the factory, I'd buy one for the $60-odd bucks they cost plus fitting or do it yourself. I've read here that they plan to enlarge the cooler they stick in the aircon condenser but that isn't a proper fix. Fit the aux cooler for your own peace of mind.
Old Nov 26, 2010 | 04:08 AM
JeepaRoo's Avatar
the trans cooler is fitted in the A/C condenser? here i always thought it was in the radiator... maybe thats why the AirCon in my 2010 auto is JUNK compared to the last 2 JK's which were manual shift...
-Christopher
Old Nov 26, 2010 | 05:16 AM
ronjenx's Avatar
-Christopher
The trans cooler is attached to the lower part of the condenser, in front of the radiator.
My A/C will freeze my hands if I direct the air toward the steering wheel.
Old Nov 26, 2010 | 10:01 AM
JeepaRoo's Avatar
my 2008 and 2009 had wicked cold A/C.. I couldnt even get the windows to unsteam with the 2010 A/C button on 2 days ago in the rain....
-Christopher
Old Nov 26, 2010 | 10:04 AM
Red Wings's Avatar
-Christopher
Is the ac button supposed to help with window fogging?
To stay on topic, I didn't see and aux. cooler at any of the 2011's I looked at.
Old Nov 26, 2010 | 11:52 AM
myz28u's Avatar
I looked over the jeep this morning and it looks like the cooleris still on the condensor. I asked the dealer about trans problems they said they had resolved the issue last year
Old Nov 26, 2010 | 12:16 PM
Carpe Diem's Avatar
What they did last year was to do a reflash that adds a "hot oil" warning when things heat up too much.
Not really a fix...just a bandaid.
Another member reported that he got a hot oil warning on his 2011:
https://www.jk-forum.com/forums/show...-code-question
He hasn't posted a followup to let us know if the additional reflash actually made the problem go away.
Old Nov 26, 2010 | 01:54 PM
myz28u's Avatar
thanks for the info. ill def keep an eye onthis then. chrysler dropped the ball on this one. if i didnt have the jeep under warranty id order a trans cooler tonite. i guess until then ill just wheel 4lo with o/d off. and hope it stays cool. i should just install cooler and send chrysler the bill. haha bet they'd love that. ill let you guys know how it goes.
Old Nov 26, 2010 | 02:52 PM
Pylot7's Avatar
I got an 08 and an Aeroforce gauge. With the cooler I can wheel all day and never have a problem. Trans never gets over 200.
Put a cooler in yours. If you wheel without one the tranny will over heat. If you push it after it overheats it will spill fluid on the exhaust pipe and it can catch fire.
Once thing you can do is run the ac when you wheel, it does make a difference in the tranny temp.
