2012 2 door - tore off my rear license bracket off-road...
Old 02-20-2014, 08:20 PM
Matthewd5's Avatar
Default 2012 2 door - tore off my rear license bracket off-road...
Hello.
the only reason my plate+bracket didn't get totally left behind and lost in the woods was the power cable for the license plate light.
the bracket is staying on just barely! I haven't even called the dealer because I know it will be a couple hundred bucks with the plate lamp being part of the whole structure...
I thought I would check on here to see if anyone had a source for oem parts like the license plate holder?
matthew
Old 02-20-2014, 08:22 PM
AlexjeepVb's Avatar
I bought one for my 2010 a while ago after someone hit it. I don't think it was that bad like 80 bucks or something. Just look on ebay also, Im pretty sure you can get one for cheap.
Old 02-20-2014, 08:33 PM
Matthewd5's Avatar
That's way cheaper than I thought, I will give them a call tomorrow
Thank you
Matthew
Old 02-20-2014, 08:40 PM
Rubichronic's Avatar
Try a wrecking yard or three. JKs are common enough you should be able to find one.
Old 02-20-2014, 08:42 PM
Matthewd5's Avatar
I just found a new oem one on eBay for less than $50 including free shipping!
Old 02-20-2014, 10:08 PM
ToolManTimTaylor's Avatar
Dang I got one brand new sitting here in ct.
Old 02-21-2014, 12:15 AM
Mark Doiron's Avatar
Many, many aftermarket bumpers provide for repositioning the license plate holder. You should be able to find one for free, or at most a couple bucks and shipping from someone who removed theirs.
Old 02-21-2014, 04:56 AM
Invest2m4's Avatar
I'd take advantage of it and move the plate. Won't be the last time that thing comes off! There is a cool relocation kit that mounts it on the spare tire and then there is a deletion plug to cover the stock hole.
Old 02-21-2014, 07:11 AM
Matthewd5's Avatar
Do you happen to have a link to that?
Matthew
Old 02-21-2014, 07:17 AM
Maertz's Avatar
Matthew
ill send you mine.... its like this
http://www.northridge4x4.com/shop/po...over-17-04-112
i moved my license plate and used this for awhile, but now i comp cut it and don't need this.
Quick Reply: 2012 2 door - tore off my rear license bracket off-road...
