2013 coolant consumption
I am not sure because mine was self contained in the block and leaking into the combustion chamber. You say it is leaking on the exhaust manifold which should mean it is fairly visible on the side of the block?....unless it is a really slow leak. After the engine is warmed up, do have any water coming out of the tail pipe? Is your oil still clear and not milky? If no to either means you may be extremely lucky that no damage has occured via watered down oil. It needs to be rectified but at least you could keep driving and topping off the coolant daily.
If anyone has had a coolant flush/fill, one would need to burp the system by parking the jeep on a hill (nose up) and have the jeep running with the heater on. I would however search the "L" hose brackets located at the engine block for signs of dried coolant as the plastic parts tend to develop hairline cracks over time. Often if one has a strong smell of coolant it could be nothing more than an over filled reservoir, I tend to keep our reservoir below the marks but just keep and eye on over time. I've complain about the reservoir being too close to the radiator which heats up the coolant over time so it smells worse than it is, assuming you don't see any leaks or cracks.
Also, lets all realize that we must used the correct coolant in the system. Mixing coolants can cause a chemical reaction, gel then harden over time. I went to the shop to have the flush, but they wanted to use some no name brand I've never heard of before claiming this new coolant is "universal". I didn't trust it so I brought in some of my own coolant.
I just did a scan and the only error was my gas cap. no misfire etc so using that, I don't think I have any coolant going into my engine. That being said, there is alot of coolant going somewhere since its draining my reservoir alot. I have been tossing what I can buy in there since im going through so much. We are going to do a through look to see where it's going. I feel a little better that it's not going into my engine however.
Cold. The coolant drops so that the heater core is "gurgling" when you start the rig. after I fill the reservoir that stops. Funny today I took it for a run around town for about 45 mins or so and never got any smell from outside the vehicle after I parked it. I dont know. It's effed up.
I have found my coolant leak. PHEW. it's leaking around the bottom big hose going into the water pump. I think a new hose clamp will fix the issue. We got under the rig and looked around and saw where it's leaking. Now, to use another type of clamp or another of the same type.
