2013 coolant consumption
Old Dec 27, 2020 | 05:04 PM
  #31
OscarMlke's Avatar
Search: "Stainless Steel t-bolt Hose Clamps"
Old Dec 27, 2020 | 06:21 PM
  #32
Edsjk's Avatar
I have been checking the oil very regularly; actually, doing an oil change tomorrow, but the oil looks fine. I haven’t put any more coolant in about 30 days, level is slightly lower than it was when I filled up the reservoir. I still see water dripping from the exhaust pipe, more than the usual amount....so I’m really clueless at this point.
Old Dec 27, 2020 | 06:29 PM
  #33
DadCrawls's Avatar
The "t-bolt" is the style used for turbo couplings and high-pressure connections. The surface has a more uniform contact area so there are fewer pinch points and less chance of the hose creating a leak. They tend to be a little wider and taller so if space is an issue it may not fit.
I spent some time fishing in Conception Harbour and Gander, miss the rock.
Old Dec 28, 2020 | 12:55 AM
  #34
Kojack's Avatar
Cool. I will put one of them on when I can find one. Yeah the rock is an awesome place for sure. Lots of back country running here.
Old Dec 29, 2020 | 04:15 AM
  #35
resharp001's Avatar
Loved
Community Favorite
Originally Posted by Foxrider68
I did, i have been incredibly busy with moving and forgot to post the results on here sorry about that guys. It ended up being the drivers side cylinder head requiring replacement, it was warped.
I totally missed this update. That really sux, but I'm glad you finally found it.
Old Jan 3, 2021 | 03:37 AM
  #36
Kojack's Avatar
I went to all the shops around and NONE have a t style clamp. I have two stainless clamps to try now. I will order some T styles and go around and replace all of them when it warms up. I just need this to stop for now!
Old Jan 10, 2021 | 11:40 AM
  #37
Kojack's Avatar
I got it done. The stock clamp was shot, I squeezed it open and it just stayed open. There's my problem. I put the normal clamp on tight and it is not leaking. I will get some t styles for my hoses. I don't trust those stock ones now.
