2013 high RPM's???
Old Dec 6, 2012 | 04:53 PM
Sharkbait98's Avatar
Default 2013 high RPM's???
Like the title says it seems that my new jeep runs a little high on the rpms at highway speed, is this usual?
specs: 2013 deep cherry red 2dr 4x4 hard top
trans: 5spd auto
gears: 3.73
tires: stock 255's on steel 16's
miles: 1300ish
while on cruise control (relatively flat ground) @ 70mph im at 2600RPM
@ 65mph im at 2500RPM
to me this seems a bit high for what i have come up with searching, what do yall think? anyone got this set up and same results?
Thanks
Old Dec 6, 2012 | 05:09 PM
Pete1971's Avatar
I would say that's normal, although I have a 12 with 3:21's @ 70 I'm at 2000 so with your higher gears I would say your right on the money
Old Dec 6, 2012 | 05:25 PM
ranjr's Avatar
Sounds right. My '12 Rubi with 4.10s ran a tad higher until I went to a taller tire.
Old Dec 6, 2012 | 08:03 PM
Thanks for the replys, the reason i question it is because i found another thread (sorry cant find it again of coarse) but it was said with same set up he was at 2300rpm's at 70mph that why i ask
Old Dec 6, 2012 | 08:05 PM
Skid_Kid's Avatar
I have a 2013 Rubi and I run the same rpm's.
Old Dec 6, 2012 | 08:23 PM
Is it possible i may have 4.10 gears then, even thought i ordered 3.73 and it says it on sticker? Check vin? I dont realy want to crack open the dif and count the teeth it being brand new fluid and all. Is there another way
Old Dec 6, 2012 | 08:27 PM
Skid_Kid's Avatar
I have 3.73 gears. Your running the same size tire as a Rubi with a smaller rim. I think your spot on.
Old Dec 6, 2012 | 08:31 PM
Dont rubicons come with 410's standard? or did u change em to 373's
Thanks
Old Dec 6, 2012 | 08:36 PM
TheTerminator's Avatar
You said you have 255 tires with 16" steel wheels. As far as I know they don't have stock tires in this size. You probably meant to say 225 tire? If so, then you need to take that into account, as it's more of a 28" tire, not 31". With a 28" tire your RPMs at your speeds according to rpm calculations should be:
@65mph: 2415 rpm
@70mph: 2601 rpm
With a 31" tire it should be:
@65mph: 2181 rpm
@70mph: 2349 rpm
Old Dec 6, 2012 | 08:40 PM
Skid_Kid's Avatar
Thanks
With the tow package they do. I did not want to pay for it. Plus I plan on going to 5.13's with 37's.
