2013 high RPM's???
You said you have 255 tires with 16" steel wheels. As far as I know they don't have stock tires in this size. You probably meant to say 225 tire? If so, then you need to take that into account, as it's more of a 28" tire, not 31". With a 28" tire your RPMs at your speeds according to rpm calculations should be:
@65mph: 2415 rpm
@70mph: 2601 rpm
With a 31" tire it should be:
@65mph: 2181 rpm
@70mph: 2349 rpm
@65mph: 2415 rpm
@70mph: 2601 rpm
@65mph: 2181 rpm
@70mph: 2349 rpm
@65mph: 2113 rpm
@70mph: 2275 rpm
If you do happen to get a tire that is 33" mounted (this tire is likely going to be advertised as a 34"), it will be:
@65mph: 2049 rpm
@70mph: 2207 rpm
Check this out, it has all the answers and it's accurate...
http://farm8.staticflickr.com/7159/6...9b861446_b.jpg
I have a 2013 JKU Sport with 3:73 gears,auto and 255/75/17 tire package I recently went on a 500 trip and averaged 21.2 mpg @70mph at around 23-2400 rpm.If I went up to 75mph
it went down to 17 mpg.I ran 36 psi. in the tires which increased to 38 as the tire heated up.
