2013 jeep engine oil pressure switch malfunction.
Old 10-29-2014, 02:37 PM
hermesgrafix's Avatar
Default 2013 jeep engine oil pressure switch malfunction.
P0520
See photo for actual code. Looking to see if you can help me out. First location of the switch. Thought it was the one on side/ back of drivers side engine. Connector has 2 pins. Is that it? Anyone have a picture of it? Jeep is under warrenty but dealership will take about three weeks to diagnose problem and order part. Plus the sensor is on back order through them possible get in a month. Think i just might change my self with an aftermarket one if i can find location. If anyone has a good picture of it wpuld greatly help me find it. Thanks.
Old 10-29-2014, 04:41 PM
Exgie's Avatar
Originally Posted by hermesgrafix
P0520
Attachment 582180
I don't have a picture of one.
A factory switch isn't horribly expensive, you might try here.
Engine Oil Pressure Switch for 2013 Jeep Wrangler|5149062AA
Generally they are near the oil filter or oil filter housing.
Old 10-29-2014, 04:57 PM
JKenn's Avatar
My 2013 JK Sport just had its Oil Pressure Sensor replaced by my very good Jim Manning dealership in Dinuba, CA this past week. It's located down on the driver's engine side, taking the tech about 90 minutes to change it out under warranty.
Old 10-29-2014, 07:07 PM
Is it the larger on on the drivers side toward the back? Happen to have a picture? Want to make sure i have the correct one. Not sure. That one i removed the plug and the one i got from local parts store had one pin and the factory one has 2 pins. Not sure if one is a sead pin. Thanks.
Old 10-30-2014, 05:54 AM
JTB488's Avatar
http://www.rockauto.com/getimage/get...Airtex/1N2.jpg
Old 10-30-2014, 03:20 PM
Thanks for the picture. Still lost. Only thing i am finding is a sensor on the drivers side aft areas on the block. Difference between the picrure and the one in mine is the one inhave has a larhwr attach point, almost double the size of the picture provided. Know i did not post earlier but i have the v6 3.8. Thanks.
Old 10-30-2014, 03:59 PM
airforce26yrs's Avatar
Do a Google search of "5149062AA" and you will get a lot of information/pictures along with places to buy it. for sale on Amazon.com for about $3b and Jeep Hut/Crown Automotive for about $29.
Crown Automotive- Oil Pressure Sensor- Replacement Part- 5149062AA - JeepHut
Amazon.com: Mopar 5149062AA Engine Oil Pressure Switch: Automotive
Old 10-30-2014, 04:00 PM
JTB488's Avatar
Looks like it's just above the oil filter.
Switches Drivetrain. Fits: WRANGLER | Mopar Parts
Old 10-30-2014, 04:01 PM
???????? You should have the 3.6 V6 not the 3.8.
Old 10-30-2014, 04:35 PM
Adgreene1's Avatar
There is no such thing as a 2013 v6 3.8. Change happened end of 2011 from 3.8 to 3.6.
Quick Reply: 2013 jeep engine oil pressure switch malfunction.
