2013 Jeep Wrangler track bar question
Old Aug 31, 2022 | 02:51 PM
dvibbert's Avatar
5 Year Member
Default 2013 Jeep Wrangler track bar question
Can anyone tell me dimension center to center on a stock OEM trackbar? Helping a buddy out with his Jeep to take it back closer to stock but he wants to replace the trackbar to stock length
Old Sep 1, 2022 | 12:18 PM
XJRefugee's Avatar
dvibbert, question for you ... your buddies 2013JK has stock suspension, stock springs ? my concern is that if it has a lift the trackbar dimension would not be the same as stock and it will shift the axle over to the drivers side a bit.
Old Sep 1, 2022 | 12:39 PM
dvibbert's Avatar
5 Year Member
Default Trackbar
It has rubicon springs with spacer for leveling. He just want to take it all back to stick and the trackbar dimension is his biggest question
Old Sep 1, 2022 | 04:24 PM
XJRefugee's Avatar
I measured an old stock track bar take off and it checked to be 32 3/8".
Old Sep 1, 2022 | 04:30 PM
dvibbert's Avatar
5 Year Member
Center to center. Perfect thank you very much!!!
Old Sep 1, 2022 | 04:53 PM
resharp001's Avatar
Loved
Community Favorite
That spacer for leveling, even if small, is going to throw that measurement off a touch. In this case it's pretty simple if using an adjustable bar cuz you just need to center that axle regardless of what the length is. That is a good starting measurement but you still may need to tweak it a touch longer due to the spacer on top of the spring.
Old Sep 2, 2022 | 06:49 AM
XJRefugee's Avatar
Resharp, I do agree with you and it would smart for the OP to consider you comments...
Old Sep 2, 2022 | 06:57 AM
dvibbert's Avatar
5 Year Member
I agree with everything said. He is now taking it all back to stock and removing spacers and installing the original springs. Thank you all for the information
