2013 moisture under floor mats
Old Apr 29, 2013 | 05:30 AM
Jdrage5's Avatar
Default 2013 moisture under floor mats
Has any one experienced moisture under the driver and passenger side floor mats? Not sure what it is. Thinking it may be the AC.
Old Apr 29, 2013 | 08:00 AM
flatattack's Avatar
Yes, washed her up last Thursday and when I went to vacuum I noticed the driver side floorboard was wet. Not sure if it happen while I was washing so I shop vac'd it up and will keep an eye on it for the next couple months. Passenger side was dry. Mines a '12.
Old Apr 29, 2013 | 08:01 AM
2012 Sahara's Avatar
Probably a roof leak.It took 5 trips back to the dealership to get mine to stop leaking.
Old Apr 29, 2013 | 04:30 PM
blisscal's Avatar
It's either your door or roof seals.
Old Apr 29, 2013 | 05:23 PM
ilikeguns's Avatar
are your drain plugs definitely still in?
Old Apr 29, 2013 | 07:31 PM
jbry311's Avatar
I live in Florida and humidity is obviously a problem. There's no leaks whatsoever in my jeep and I still get condensation under my mats. Just because it's wet doesn't mean you have a leak.
Old Apr 29, 2013 | 07:54 PM
slopoke's Avatar
condensation from a/c
Old Apr 29, 2013 | 08:02 PM
Tdecristofaro_7907's Avatar
This is the "mystery" leak. My 2011 did it. Started of as moisture and I thought water from my boots made it down under my floor liners, but one day I found 2 inches of water under there. ( no signs of leak on interior) I took it back to the dealer and they put "beefy" seals and adjusted my door for a closer fit. That was the end of my 2 inches of water, but the moisture appears, then I don't see it for another 3 months. Unfortunately i have no answer
Old Apr 30, 2013 | 01:58 AM
Jdrage5's Avatar
Thanks Guys I do have a leak on the drivers side every time I open the door and water is on the roof. But not sure about the passenger side. Had the moisture ion the floor both sides and it had not rained for a week or so.
Old Apr 30, 2013 | 01:59 AM
Jdrage5's Avatar
Side note I also have 1/2 doors
