2015 with 6,000 miles; oil leak????
Old May 15, 2015 | 10:17 AM
newjkman's Avatar
Default 2015 with 6,000 miles; oil leak????
I have a 2015 2D with 5,900 miles on it. I pulled it out of the garage and noticed an oily spot on the concrete. I crawled under the jeep, and saw motor oil around the two rubber plugs, and back to the cross member. I checked my dip stick and it looks to be about a 1/2 quart low. I also checked the transmission fluid, and it was fine. I have always changed my oil myself, and rotated the tires because I'm very picky. I changed the oil at 4,200 miles. I climbed up on the bumper, and shined a light next to the filter housing. There is some oil at the base, and on the outside of the filter housing. The filter seams snug, and the o-ring looks good. Could the oil be coming from the filter and dripping down the transmission area? I can't get it to the dealer until next Tuesday.
Old May 15, 2015 | 11:03 AM
Cutman's Avatar
There is a thread on this. BAD OIL LEAK PROBLEM!!! I think is how it is titled. Seems to be becoming somewhat common but not at a recall level yet. Google that and see if it's what's happening to you. The signs seem similar.
Old May 15, 2015 | 12:11 PM
jeepmojo's Avatar
Default boy they just
keep getting better and better every year huh? technology
how long has the pentastar been out now ?
Old May 15, 2015 | 03:28 PM
RoysRig's Avatar
Yeah, just don't buy the first year.....or the second.... or the third........
Old May 15, 2015 | 04:04 PM
rob_engineer's Avatar
Are you 100% sure you got the correct filter? There are other threads about the fact that there was a change to the filter, even though the engine is the same. Also, did you replace the o ring and make sure the old o ring was removed first?
Old May 15, 2015 | 04:23 PM
Cutman's Avatar
^^^the o-ring. That effer.
Old May 15, 2015 | 04:26 PM
BlazeJK's Avatar
I have a 2014. Within 6 mos, I had an oil spot on the drive. Took it in and found out that it was the rear main seal. A known issue. Warranty covered it and hasn't leaked since. Now if they can only fix the damned heater control, I'd be good as gold. Already had it replaced once, and it's acting up again. Sometimes have heat, sometimes not...
Old May 24, 2015 | 04:18 AM
ThatguyJZ's Avatar
I've been reading about people having issues on '14 and some '15 model 3.6's due to the oil cool/filter housing cracking and leaking down to the area you mention. There's a thread over on wranglerfoum and a few on here that mention it. Apparently they re-designed the part after '13 so it would be compatible in other model Chrysler products, which is why the oil filter is different after '13.
Old May 24, 2015 | 05:37 AM
tribulation138's Avatar
Is it comeing from the front crank seal. Mine used to and would drip all the way to bottom of engine.
Old May 24, 2015 | 06:42 PM
fultonromero12's Avatar
With that mileage I would just take it in just to have it documented and fixed in case you have a future problem.
