3.6 serpentine belt
Old 08-14-2014, 03:36 PM
tnt008's Avatar
Default 3.6 serpentine belt
I own the 3.8L. Friend owns the 3.6L. He asked me to give him a hand changing his belt. How much harder could it be I thought. Well apparently its a lot harder. Do you need to remove the alternator? What other parts of the engine do you need to dismantle? I mean really, could you make a belt change any more complicated?
Old 08-14-2014, 03:53 PM
tribulation138's Avatar
I know on the 3.8 it took me 5 minutes. Just press down on tensioner with 3\8 ratchet head. how is the 3.6 different?
Old 08-14-2014, 04:00 PM
tnt008's Avatar
I know. I have the 3.8. The 3.6 is a completely different pulley set up. The alternator seems to be the problem, can't get the loop around it. Needs to be removed so it seems.
Old 08-14-2014, 04:18 PM
ronjenx's Avatar
The 2012 service manual says to remove the alternator support bracket. No mention of removing the alternator.
Old 08-14-2014, 05:32 PM
2k12jk's Avatar
I use a 36" .5" ratchet reduce to 3/8" to pull the tensioner back, it's little tough cause it's hydro
Quick Reply: 3.6 serpentine belt
