3.6L break-in
On a rebuild not a factory new engine I actually do it at about 50 miles the first time. I was lucky tho and surrounded with engineers who new how to build engines and make money so not a waste of time in the long run. first few miles on cheap oil so rings seat better.
I would just throw in regular oil and change it at 1000 miles. If you just did pistons and rings you won't have as much wear as a new motor breaking in everything. Is this the original motor? in my experience hydrolock causes a lot of lower motor damage.
3.6L break-in
Or just normal Dino oil?
Many people have zero issues with their engine break-ins, problem is that if you do have issues that the break-in oil would prevent your engine may not go 100 miles. Break in oil has zinc in it designed to keep metal parts from grinding on each other when soft so....bad... I don't know all about it, I've heard you don't really need it for certain parts but I've never done a partial rebuild so I never looked into it. Don't even know how long you should run it as I've always changed it after a cam break in period.
Yep. I'm sure if you stop by the parts department at your local dealership they can order you some actual break-in oil, but just to warn you, it's pretty expensive. Go through the normal break in process and then do your oil changes after that as regular ones. (Using whatever oil you prefer). As long as you did everything correctly you should be golden. Just stay out of lakes lol
I'm guessing this was a used 3.6L that you partially rebuilt.
If you're just breaking in Rings and Pistons, I would run regular Dino and change after 1000 miles.
Drive it at varied speeds for first 500.
