33s with no lift
Old Oct 7, 2013 | 04:25 AM
Derrick_Merwin's Avatar
Default 33s with no lift
Can you run 33s on a jeep jk with no lift on stock wheels or do i need to get wheels with a different amount of backspacing I know a guy that's running 33s with no lift but his wheels have 3.75 backspacing and the stock wheels are 4.7 or something
Old Oct 7, 2013 | 04:39 AM
8000ft's Avatar
I've been running 285's (32.8") for years, no problems, no rubbing. MUST run 1.5" spacers, checkout Spidertrax Off Road.
Old Oct 7, 2013 | 04:51 AM
catahoula's Avatar
Old Oct 7, 2013 | 04:57 AM
GoBig's Avatar
Ran them with no problems, as well.
Old Oct 7, 2013 | 05:22 AM
kh202's Avatar
The need for spacers depends on width for 33's.
Old Oct 7, 2013 | 06:00 AM
seribralcrow's Avatar
This is correct. There are a number of threads on here that discuss this topic. I would suggest searching for tire specifics.
Old Oct 7, 2013 | 06:33 AM
jtphoto JK's Avatar
33x12.50x16 on PC wheels 4.5" BS. No lift no problem other then rub a bit on plastic airdam at full lock.
Old Oct 7, 2013 | 12:56 PM
Canada's Avatar
Running a "true" 33" tire (255/85 KM2) on the stock 16" steel wheels, I have no problems lock to lock with rubbing.
Old Oct 7, 2013 | 01:51 PM
jeepmojo's Avatar
Default 33 in trail grapplers are
less than 32 like 31 /34 inches they look great and no issue trail grapplers and 16 inch b72 wheels
from dtd great prices shipped to your door Im pleased with the results I alternate the stock ones and these and no recalibrater needed Click image for larger version
ID:	503330Click image for larger version
ID:	503331 the trail grapplers give it a better stance however the stock ones are better for gas milage so with gas prices high I use the stockers lol
Old Oct 7, 2013 | 09:02 PM
Tripletsi's Avatar
The stock Jeep wheels have a backspace of 6", not 4.7". You can run 33's on your stock Jeep depending on the width of tire you buy (10/11/12.5). Your best bet would be to install some quality 1.5" wheel spacers (which changes your backspace to 4.5") and you won't have to trim anything. Spidertrax or G2's are hubcentric and are a great buy, stay away from 1.25" spacers unless you want to cut off the ends of your lug nuts.
