500 mI. Oil Change??
the jk has a monitor for the oil condition. it will tell you when it needs to be changed.
unless you want to do it just to switch to synthetic, but that seems like a waste.
driving style has an effect on oil change interval.
Speaking of oil change....I change mine evry 3000 miles.....for some reason my "change oil" message is coming on and it has only been 1850 miles. I have not changed the way I drive so I have no idea why.
Me either. Synthetic helps prevent metal breakdown to a much greater degree than regular oil, to add sythetic right out of the gate will prevent parts from breaking in together.
For what it's worth, I changed mine at 500 and used regular oil to continue the break in procedure. At 2500 I changed again and used synthetic and now change at the regular intervals noted in the manual--6000 miles, 12000 miles, etc.
Oil changes almost seem to be a mystical ritual
I swapped out the factory build oil with the 5w20 mobil1 synthetic in case there were any real tiny particles of metal sloshing around after reading about oil changes here.
The 2008 manual states you can use synthetic oil as long as it's the same rating as the dino oil.
I'm not sure what the bonding issue is about but there's a number of cars that roll right out of the factory with synthetic oil..
I don't think the synthetic is really gonna affect your break in. There are lots of higher end cars, especially the german stuff that comes from the factory filled with synthetic. I switched at 500miles and havn't had any problems. Doesn't use any oil at all. Your mainly worried about breaking the piston rings in. As long as you work the engine like your owners manual tells you too for the initial break in, you should be fine.
