5th tire?
Just put 315/70-17 on my stock moabs. The spare will not fit "as is" on the stock bracket. 2 things have to be done if you're trying to stave off buying a tire carrier: 1) you'll need extended bumpstops (daystar makes them, I just used heater hose that fits in the stock bumpstops...ghetto, but it keeps the tire from moving, 2) you need a relocation bracket for the spare. This raises the tire up and out so it will actually fit on the stock carrier (MBRP makes one, both items are on quadratec). Know that if you're going to run 35's, this is only a temporary fix. You'll need a tire carrier eventually.
Originally Posted by JKjeepguy
I am just about ready to order 5 new tires the same size as your spare. What size wheel spacer are you using for the spare? Is it like the SpiderTrax spacers people are using on the other 4 rims? Are you able to buy just one spacer anywhere? I've only ever seen them sold in pairs. Is the reason for using a spacer on the spare because the tire is hitting the brake light or is there another reason. And finally...would you happen to have any pics of the spacer?spare setup? And if you are running 275/65/18's, do you have any pictures of that with or without spacers?
Sorry for sop many questions - I'm new to this and want to have the spacer before I get the tires installed... Thanks!
It will depend on wheel offset. And whether you will use a wheel spacer. Many folks are carrying 35s, but there have been occasional reports of damage to the rear gate. I'll let you search for those. Most don't have a problem, however, but a few do. That probably depends a lot on the specific tire (there was 8 pounds difference in weight between different brands when I was researching my Jeep for 35s), and how hard you are on your Jeep (bouncing around on rocks or potholed roads being problematic). I ran 33s on 4.5" BS wheels without a problem for a couple years--used a couple radiator hose sections over the tire bumpstops to keep the spare from bouncing around (this was before Daystar came out with their extensions).
