6spd transmission TSB?
Old Mar 21, 2007 | 12:59 PM
chris_386's Avatar
Default 6spd transmission TSB?
I was just reading in another section has anyone heard anything about this?
Originally Posted by Florida Geo Crawler
IMHO, they've had a TSB on the 6-speed manual tranny and really need to resolve that problem at the factory before sending out anymore. It must really hurt D-C to replace a couple of washers and spacers on each 6-speed built! I've had my Jeep all of 10 days and it's in the shop for this fix as we speak. :sad:
Keep up the faith brothers! It really is worth the wait!
https://www.jk-forum.com/forums/show...9519#post49519
Old Mar 22, 2007 | 05:01 AM
Florida Geo Crawler's Avatar
Yes , check the TSB section, look for "improper pre-load on the throw-out bearing".
Old Mar 25, 2007 | 10:08 AM
clubber's Avatar
All jk's with 6-speed have to be brought in to the dealer for this ? Is this a recall?
Old Mar 25, 2007 | 12:35 PM
superboo's Avatar
in the TSB it says to put it in neutral with the parking brake on. then turn it on and depress the clutch slowly to the floor. if there's any point where you get a squeal/squeak, then you need it. mine doesn't squeak. plus my build date is feb 16th. i'm hoping mine got out of the factory just after this was figured out and the fix is likely included.
http://project-jk.com/jeep-jk-tsb-re...ow-out-bearing
Old Mar 25, 2007 | 08:05 PM
Gasser's Avatar
Mine does this too. It was fine at the dealer and when I drove 75 miles home it started. Its louder now after about 250 miles. I just fear the fix may be worse than the problem. The tranny shifts fine now. If those monkeys take it all apart it may make things worse. I can't hear the noise when I am driving and I don't let it sit and Idle while I stand outside talking so it really does not bother me that much. If it gets terrable then I may let them muck with it.
Jeff
Old Mar 26, 2007 | 01:24 AM
clubber's Avatar
Jeff
I feel the same way about the dealer .I always think they will make things worse or break something else while there repairing the vehicle. I have about 800 miles on mine and so far NO squeeks or clutch noise at all. Only time will tell........
Old Mar 27, 2007 | 09:06 AM
Gentlemen, please listen up. . . .I had my Sahara in for the throw-out TSB repair this week. It took 2.5 days instead of the 1 necessary. My dealership had to "cut" off bolts to remove the exhaust to get to the tranny to perform the service. Ok, I can understand that. But, when I picked it up on Friday, the "check engine" light was on. After checking the computer code reader, it turns out that the tech melted my O2 sensor wires on the replaced exhaust system!! SIX days later, it's FINALLY ready!!
Be forewarned that you make sure these so-called factory-trained techs know what the H@#l they're doing BEFORE you schedule your work.
Old Mar 27, 2007 | 10:27 AM
Gasser's Avatar
Again, as I said above in my post. I don't want these monkeys messing with my jeep unless it is really broken. If the sound just gets unbearable then I may think about it. Sorry you had to go through this. Please keep us updated on how the repair faired. Is the noise completly gone now? Does your jeep drive any different?
Jeff
Old Mar 27, 2007 | 01:34 PM
troy_boy's Avatar
Originally Posted by BeerMonkey
i got that. it goes in on april 2nd for the fix dealer said they would have it for a a min of 2 days,but i did get them to give me a loaner (orginally they werent goin to)
Dealers can kizz my big toe! Thats all they get and I wasnt even gona let em do that!
Old Mar 28, 2007 | 05:21 AM
I got my Sahara back and the dealership performed the proper repair on the throw-out TSB. However, putting me out for 6 days, they only credited me the damage waiver on the rental car (a crappy PT Cruiser; no offense to people who own one), and gave me a free oil change (whoopity S%$#)!
Well, my Jeep runs great and It'll NEVER be back to that dealership again!
If ya'll have to have yours repaired, watch your dealers service dept. like a hawk.
