AC Cold air Not Working!!
Greetings,
Started my 2011 JK and found that air conditioning is not working with cold air, It is always blowing heated air, not matter where I move the temp. controller knob !!!
I verify the compressor and it is engaged. Any recommendations?
I agree with above. If it is definitely heated air and not ambient air the blend door isn’t working. A bandaid would be to shunt the heater core. If it’s February and you want ac you probably don’t need heat. If air isn’t moving across the evaporator correctly I would be hesitant to use the ac because you can slug the compressor and the bill can add up
