Air Conditioner Performance
Old May 14, 2009 | 10:32 AM
Iblowstuffup's Avatar
Default Air Conditioner Performance
How does everyone's air conditioner work?
Mine sorta seems bad. I took it into the dealer, and they said there was a leak. They fixed it, and it seems better, but it still sucks.
It sorta cycles on and off seems like. When it gets cold, its nice, but that only last 10-20 seconds. Then it seems to warm up a little and cycle back and forth. Does anyone else noticed this? When its cold, it blows about 42-45 degrees. When it warms up, its about 50 - 55. Then it cycles back on and blows colder.
What do you guys think?
Old May 14, 2009 | 10:33 AM
l3itch's Avatar
Mine's cold all the time it's on. It's too cold for me I'd rather have the top off Last time I turned the air condition on it smelled like Florida swamp mud
Old May 14, 2009 | 10:35 AM
jasruby's Avatar
I have no problems with mine...but I am positive I have seen a thread on here before, and others had the same problem.
There are also quite a few write ups on insulating the hardtop, which for some also helps.
Old May 14, 2009 | 11:13 AM
pearl-drum-man's Avatar
Mine works well on the rare occasion that I use it.
Old May 14, 2009 | 11:51 AM
RedneckJeep's Avatar
The general rule of thumb for dealers and A/C shops is if the A/C can blow 20 degrees cooler than the ambient temp outside, it's doin it's job. It's a cop out, I know, but that's usually the standard. Mine works fine, by the way.
Old May 14, 2009 | 11:52 AM
Pics please.
RWA612's Avatar
Mine is very cold, I don't use it too often but when I do it's cold the entire time.
Old May 14, 2009 | 11:54 AM
my girl blows so hard its unbelievable
Old May 14, 2009 | 12:10 PM
JeepaRoo's Avatar
the A/C issue is the fact the due to the way EPA measures fuel economy car manufacturers are required to test MPG with the A/C on.. so they tend to cycle the unit out when the output vent temp is around 50-55 degrees which is cool but not the ice bone chilling cold that some (including me) like...
Jeep uses an H-valve (a fake TxV sort of) and an evaporator temperature sensor to control the compressor cycling...
the evaporator temperature sensor is a wierd value thermistor... its not a standard 10k device... however it can be skewed allowing the compressor to stay in longer...
these devices typically have a 5% tolerance level in them which can result in different people having different results...
I ended up popping a 20K ohm resistor across (in parallel) with my sensor and am now getting 40-45 degree air on average from the vents.. an 18K ohm resistor dropped the vent temp to the high 30's however It also started to freeze the evaporator core.. so I backed off a little...
MUCH better than the original 50+ degree air..
because of the differences in the tolerances of the sensors you may need t play with tyhe resistor values a little to get it calibrated just right.... the lower the value resistor the colder the air although more risk of freeze-up and freezing up solid *CAN* damage the air-conditioner if left out of control.. the higher value resistor the less effect it will have...
id say 15k-25k ohms is the range needed..
-Christopher
Old May 14, 2009 | 12:11 PM
Thanks for all the replies. My air conditioner is not cold. And its upper 80's lower 90's here. Barely does the job. When you spend so much on a vehicle, you sorta want it to work. I guess I'll take it back to them and let them tell me its as cold as R134a gets... Anyone else with this oscillating / cycling compressor problem? What could that be?
