Air Filters
Air Filters
Is anyone using a K@N filter or other cotton replacement? Looking to see if there was any noticable difference from stock. I had done this in both of my mustangs for performance, but I am looking for savings since my JK will soon spend more time in the woods and I could have to replace more often. Thanks.
Then be prepared to clean it quite often. With a dry paper air filter, you can tap alot of dust out, and reuse it, after driving in severe dusty conditions. A k&n however is coated in filter oil. It clogs REALLLLY quickly with fine dust in severe dusty conditions, and you aint tapping the dust out of it. Its stuck like glue, actually, dust turns into this..... Oily.... Paste like substance on an oiled filter.
I was in the army, and many times we would blow air filters out for m1 tanks and trucks and such. Being we were in a "desert" climate, with a k&n, wed have to wash them hourly, with paper filters, daily, you blow air reverse flow through filter with compressed air, and put it back in. Easy as pie.
If you really just want to run a CAI then look at the aFe brand. They make one that does not have to be oiled. To clean just rinse with water and mild soap, let dry then reuse. Makes a small difference, not much but if you get areally good deal on one then go for it.
If you want an advanced air filter, consider Amsoil (no affiliation; don't use them much personally). They have a microfiber filter that should work well in dusty conditions but isn't oiled, so can be vacuumed clean like a regular paper filter.
http://www.amsoil.com/storefront/eaa.aspx
Location: Simi Valley, Ca., Taylorsville, Ut. and places in between
1 Post
FWIW, I had a Amsoil on my Dodge diesel and it worked quite well.
All thats needed to clean was remove, blow it off and put it back in.
Problem is, they dont list one for the Jeep.
K&N kit -one week in
I did the install on the K&N cold air kit a week ago and I am already noticing a difference in both gas mileage and pick up. My mileage over the last week (mixed city/highway) is averaging 21.5mpg and the acceleration is definitely better.
Not a green race car by any means - but any improvement over stock is good
Installed a K&N drop in 13K ago. Checked the tube running to the throttle body last weekend and it is clean as a whistle. I do run in some dust so yeah it's probably time for a wash. I'd feel more inclined to wash it if my mileage hadn't jumped up 1 mpg with the cooler weather the past couple of weeks.
I like my AFE dry drop in filter, simply for the fact that I do not have to oil it. I can clean it on the trail if I need to by tapping it on a rock. That is supposed to bring it back up to 80% filtration without washing it out. I dont know about all of that, but mine has done what I wanted it to do and is still holding up well after about 40K miles. I am toying with the idea of getting an enclosed cold air system like the one Banks or AFE makes, but I am still in the researching stage.
