Another reason to change motor oil when its hot
Old 12-02-2015, 07:33 AM
jk_sea's Avatar
No problem removing the plug on mine, hot or cold.
A 13mm socket does the trick every time.
Then again, the torque spec is only 20 ft/lb. I've never had a leak, never rounded off the head of the drain plug. Some people reef on those things and it's completely unnecessary.
Old 12-05-2015, 06:27 AM
Eandras's Avatar
I will change my oil hot or cold. I inspect the oil drain plug and replace at any sign of rounding off.
Ed
Old 12-06-2015, 02:41 AM
Macman1138's Avatar
Originally Posted by LidLess07X
try a Fumoto valve.
I have one and I love it. Takes a lot of bother out of changing oil.
Old 12-06-2015, 04:34 AM
Eandras's Avatar
I always wanted to try the valve but was Leary of it snapping off if it got hit with debris from the road. Would valve be a reason for the dealer to deny warranty if there is oil issue.
Ed
Old 12-06-2015, 06:02 AM
karls10jk's Avatar
I have the fumoto and cracked the nipple off on a rock. I got home a week later, was out of town, and not a drop of oil had left the motor. It's a tough piece of equipment, it just drains slower than I have the patience for.
Old 12-06-2015, 06:07 AM
Eandras's Avatar
I have 5 vehicles in my household and although the valve may drain slower than the drain ply it would still save me time as I could drain the oil and not make a mess.
I don't go off extreme off roading just some minor trails and beaches. Guess I'm going to order for the wrangler and see how it goes.
Thanks.
Ed
Quick Reply: Another reason to change motor oil when its hot
