Any other "07"s need piston rings
The JK factory service manual says 100 psi is the minimum it should be.
either way. get a 3.8 with no oil issue and do a test. as for the mechanic, go to a mechanic where you can watch him do the test, ok, maybe you dont trust him but you want to be there to confirm the results
I'm gonna talk with a guy I work with tonight who used to be a mechanic for dealership about helping do my compression test. He was the one who recommended the test in the first place. He knows all the tricks that stealerships try and get money out of people and that's why he got out of that business. I trust him cause he's worked on other people cars and has 2 drag cars so he very knowledgable. Maybe if we can get together this weekend to do the test I'll try and get code for where the motor was made at. Will post findings asap.
Originally Posted by chknkatsu
awesome, all results should include the vehicles model year and mileage and whatever else info that might help. maybe its only a trend in '07 and '08s? i honestly hope since i have a '10
The number is there. Did you clean the area with a rag before you looked? It took me several tries to get it clean enough to read the numbers.
If 100 psi is the minimum that's a terribly low number. That's the kind of number you would expect from a 70's engine with an 8-1 compression ratio and a tight LSA cam(stockish). I really hope that was a guess and not what the manual really says. 150-200 psi would be good numbers. All readings should vary by less than 10%.
