Any other "07"s need piston rings
I did check it between oil changes and had to add 3 to 4 quarts depending on when i checked it I had a quart of oil and a funnel under the hood next to the battery that's how bad it was. This is why I had them start the oil consumption test.
Bulletproofjk my oil consumption test started with an oil change done by the dealer and a return check of the level ever 500 miles 1st check it was down 1 1/2 quarts... guess I failed the test!
Went to the dealership this morning after getting off duty to get my loaner vehicle, the JK was sitting there hood open, engine disassembled waiting on the extended warranty adjuster to show up and approve the repair since it will be over $1000 dollars. Just wondering if this will happen again in another 28,000 miles? Took a few Pics of what it looks like if some can tell me how to get them on here I'll post them
Well oil consumption test round 2 went about the same as round 1. They told me it only uses 1/2qt per 1000mi which, to them, is acceptable. Last month they told me when I went in to start the test that my PCV valve was bad, which was causing the oil usage because the tube was "full of oil". They wanted 100 bucks to install it, but I opted to do it myself for 10. I installed it that evening, following a write up on here, and I noticed when the old valve popped out, it still rattled inside, which made me think it wasn't broken in the first place.
Anyway, I took it in today and when they told me it was only using 1/2qt, they also said I still needed a new pcv valve. I told them it was brand new, and that I installed it myself the same day they told me about it. So then, after about another hour, they said the tech claimed it wasn't fully seated.
I'm pissed now because I feel like with their excuses they took away my ammunition for complaining to chrysler corporate. This oil consumption test accomplished absolutely nothing. Even if I complain to chrysler, I'm just going to have to do another test, where they'll have another bullshit excuse. I change my oil myself and it uses well over 1/2qt per 1000. I measure it out every time...I just don't know how the hell to prove that to them.
I would find another dealer to assist you with this as they do not sound like they want to take care of it
How silly, its warranty money in thier pocket
I am adding this to the engine oil threads:
The engine number is located on the rear of the block, just below the cylinder head, on the drivers side. There will be two sets of numbers. The first set is the engine number, the second set nearby is the last 8 digits of your VIN.
The second character in the engine number represents the manufacturing plant.
S = Saltillo
T = Trenton
Check your engines. Maybe we can see if the plant location has anything to do with engine failures.
S = Saltillo
T = Trenton
I know someone that has a 3.8 out on the floor. if I get a chance I'll go look at that one and try to figure out exactly where these numbers are at.
That looks well lubricated
in all the wrong places
Glad to hear they are taking care of it for you! It will be good after they get it put together the right way just cut it some slack breaking it in!
Hey Reiper, did they give indication on what they found the cause of all that oil getting past the rings to be?
Many here that have had their motors dissassembled due to oil burning have found that the rings were installed incorrectly at the factory (ie: gaps lined up on the compression rings, oils control rings all installed upside down, etc). Keep us posted, eh!
