Anybody have issues with the brake master cylinder?
I recently went to the dealer to get the gas overfill thing fixed, and the mechanic guy told me the master cylinder is leaking into the booster. I have noticed quite some time ago the pedal felt a little "softer" and it makes a "whooshing" every time I press it. Anyway long story short they were quoting me like 400 dollars and some change. I figured I could do it myself ( I've dome other stuff ) but not sure which kind to get.
Should I get a remanufactured one, or a new one?
Plus these things seem so hard to find.
Anyone have any recommendations?
Thanks.
I tried searching on here but no mater what I typed, a blank white screen is all I got.
Thanks.
There's a little known secret that TF has an oversized master cylinder but there's a Mopar piece that is fairly equivalent. Last time I checked the price was $89.....obviously you'll need to budget a few bucks for fluid but it's still cheaper than the $400 the dealer quoted. I'll look for the pn but it's from the euro models and is a direct bolt-in.
Sent from my DROID4 using Tapatalk
I believe its the one off a 2010-2011 Dodge Nitro. O possibly the one off the jk8s
Yep, jk8 I think. I'm still looking for the number, I wrote it down somewhere.
http://www.brakepadwholesale.com/ite...ESTOS&weight=5
I was under the impression from TF that the larger master cylinder bore simply moves more fluid with the same pedal travel.
Input 1 psi, output of 2psi vs the stock input of 1psi, output of 1psi (fictional numbers for demonstrative purposes only).
It would take a smaller master piston diameter to make more pressure in the lines with the same amount of foot pressure on the pedal.
