Anyone got flickering headlights????
i have had this problem since i got my rig, dont know if its the silverstar lights i put, in it but at idle, i can barely see my lights flickering, barely noticable but anoying to me. Anyone else seen this?
And any idea how to fix it?
same problem here, but am not too surprised by it. Do the JK's run the power through the circuit on the turn-stalk like TJ's? One of the aftermark kits that powers the lights directly off the battery with its own relay should take care of this. I've heard great things about the IPF kits but have yet to research much for using on the JK. I'm sure there are a bevy of good threads about headlight upgrades.
Even if you run the power straight from the battery and just use the stock wiring to trigger a relay you will get pulsing (because you will not be getting a trigger that is always on) unless you use a diode to correct the pulse. The problem is that the JK uses a pulsed electrical connection so rather than sending a constant power supply through the line, it sends several higher voltage spikes. The only way to fix this is with a relay with a diode to smooth the flow of power.
