Anyone have stock suspension measurements
Old Feb 22, 2010 | 09:01 AM
johnwaynejeep's Avatar
Default Anyone have stock suspension measurements
Does anyone have a Factory Service Manual for the 07 Wrangler X or newer?
I've seen several posts where people are having problems with road manners after a lift. I understand this is normal to a point, but there's a lot of geometry that goes into a suspension design and not always a lot of design that go into some of these lift kits. A lot of peoples problems could be solved by installing the correct components to bring their suspension geometry back in line with everything. I'd like to address this problem before I buy a lift kit. So does anyone have a FSM or any product that will identify the measurements and angles of the suspension?
Thanks a lot
Robert
Old Feb 22, 2010 | 09:20 AM
JackMac4's Avatar
I don't believe its in the FSM...at least what you're looking for. I'll double check, but i'm almost positive the angles aren't in there.
It's really not rocket science though, once you lift it you just need the track bar and drag link to be parallel. Any angle finder will get you there.
