stock jk tires???
Old Feb 19, 2010 | 09:12 PM
mark16830's Avatar
Default stock jk tires???
ok i want to replace my 2010 jeep sahara unlimited factory 255 70 18 tires with a 275 70 18 tire thats pretty aggressive tread, will i have any issues with rubbing or will it fit the wheel wells ok?? i really need to know asap any opinons???thanx
Old Feb 20, 2010 | 06:11 AM
Adam3612's Avatar
I'm sort of in the same boat as you except I want new wheels as well. I'm wondering will I need spacers to run 285/70/17's?
Old Feb 21, 2010 | 02:30 PM
coltc2000's Avatar
spacers on the 285 depends on tire mostly.
most 285 will not have any rub issue but the Goodyear Duratracs will rub slightly on track bar at full lock on most jeeps.
The 275 should not rub
Old Feb 21, 2010 | 07:14 PM
07tungsten's Avatar
I just put 285/70/17s on stock wheels and they work just fine. They are Nitto Terra Grapplers and only rub on really tight turns. Not a big deal--but I'm planning on doing a lift soon.
Old Feb 22, 2010 | 08:35 AM
Buckhead GA's Avatar
Can the 2009 wrangler unlimited sahara 4dr fit 33" tires with out any lift at all.. it's completely stock.
Old Feb 22, 2010 | 08:42 AM
AU94's Avatar
I have the same set up and got the same results. At full lock you'll get some rub but nothing to be overly concerned about.
This weekend I added Spidertrax 1.25 spacers all around. Zero rub and I think it looks a lot better, especially on the rear. The tires now just peek out from under the flares.
Old Feb 22, 2010 | 09:24 AM
JackMac4's Avatar
Typically, yes, but at worst a spacer lift or fender trim could fix you.
Old Feb 22, 2010 | 11:16 AM
revolucion!'s Avatar
33's - will it rub without spacers?
yes at full lock on the plastic airdam. FIX, remove the plastic airdam
if you're not lifting your rig i say just rip that POS plastic air dam off. it does nothing anyways.
