apparantly something is wrong with my speed control.
Old 05-27-2008, 12:07 PM
davebloomer's Avatar
Default apparantly something is wrong with my speed control.
i get codes p0579 and p0581 on the diagnostic which are both speed control codes... problem is I don't have speed control anyone know why these would be going off?
Old 05-27-2008, 03:36 PM
JPRS51's Avatar
Sounds like is needs to go to the dealer. They can scan it and tell you what set off the code.
How many miles do you have on it?
Old 05-27-2008, 04:48 PM
8200 miles.
Old 05-27-2008, 05:03 PM
JPRS51's Avatar
May just need a quick Flash done to the PCM. Have you called your dealer?
Old 05-27-2008, 05:04 PM
no, i just read that post from you..
today while at a red light behind someone my horn just started blaring! and it kept on till i shut off the motor.. even then it still randomly goes off. it would honk for about 5 seconds then off for a second or two. so i pulled the fuses and will be taking it in to them tomorrow.
Old 05-27-2008, 05:36 PM
i think i have it fixed i did the disconnect battery for 15 minutes and now my codes are gone and my horn hasn't been going off for a while!
Old 05-28-2008, 08:45 AM
JPRS51's Avatar
This may sound weird but I have seen a couple vehicles act like this that were brand new. The culprit ended up being a loose battery terminal connection.
Hope it continues to work for you!
Quick Reply: apparantly something is wrong with my speed control.
