Armrest static!!! Anyone else?
Old Oct 1, 2008 | 06:37 PM
Dr.McNinja's Avatar
Originally Posted by turtoni
Actually come to think of it when i insert my key into the jk i'm probably grounding myself with the vehicle.
No you're not, because the plastic in your key is also an insulator. That is, unless you are holding the metal part, in which case your fingers are very thin, as I don't have a lot of room between the plastic on the key and the plastic surrounding the ignition slot.
Thanks for the wikipedia though.
Old Oct 1, 2008 | 07:09 PM
turtoni's Avatar
"A ground mat or grounding mat is a flat, flexible pad used for working on electrostatic sensitive devices. It is generally made of a conductive plastic or metal mesh covered substrate which is electrically attached to ground. This helps discharge any static which a worker has built up, as well as any static on tools or exposed components laid on the mat. It is used most commonly in computer repair. Ground mats are also found on fuel trucks, which are otherwise insulated from ground as they make physical contact only with their (rubber and air) tires; obviously static discharge is undesirable during fuel-transfer operations. Similarly, in aircraft refueling, a ground cable connects the tanker (truck or airplane) to the fuel-seeking craft to eliminate charge differences before fuel is transferred.
In an electrical substation a ground mat is a mesh of conductive material installed at places where a person would stand to operate a switch or other apparatus; it is bonded to the local supporting metal structure and to the handle of the switchgear, so that the operator will not be exposed to a high differential voltage due to a fault in the substation."
http://en.wikipedia.org/wiki/Ground_(electricity)
You can ground with plastic..
Old Oct 1, 2008 | 07:15 PM
turtoni's Avatar
http://www.wikihow.com/Get-out-of-a-...ic-Electricity
"Be aware of your clothing. Synthetic materials, such as most modern fleeces, increase the risk of static shock.
Shoes are also important. For example, beach shoes with foam soles are more or less guaranteed to shock you.
When you exit the car, grip the metal frame of the door for a couple of seconds before you let your feet touch the ground. The static charge is balanced when you're still seated, when you get up the charge of your clothing doesn't have the opposite charge to hold it where it is. Having your hand on the car frame when get up lets it discharge more slowly. All you need to know is that it works.
Wear an anti-static wristband, if possible. These are sold at most electronics stores. They provide a conductive path to ground.
Open your door while still sitting in your car seat, reach up and rest your hand on the (outside) roof of the car before you slide/step out.
Touch the glass as you exit, this will discharge any electricity as well with no shock!
Use an anti-static laundry spray on your car's seats and floor.
*Hold a key in your hand and touch the metal door frame as you exit. It acts as a lightning rod and discharges the static without pain.*
Here's a simple technique: tap the door with your knuckle as you exit. Your knuckle is much less sensitive than your fingertip and you won't feel the zap.
This is actually a safety tip, as static electricity, if not discharged, has actually caused small explosions at gas pumps. You should never re-enter your car while gassing up, as this can provide more static electricity. If you must, make sure you follow the directions above to discharge the electricity before you get anywhere near the fuel pump!"
Old Oct 2, 2008 | 05:58 AM
Catzilla's Avatar
wow with is just like science class!
Old Oct 2, 2008 | 06:59 AM
Snuggly Ranger's Avatar
You can get anti static spray for clothes to spray on.
Old Oct 2, 2008 | 07:35 AM
Hwyblades's Avatar
Haven't noticed it on the arm hair...but I definitely have the issue at that soft top. Fortunately I have very short hair...OK I'm balding...or my hair would be standing straight up. Was thinking of spaying the inside of the soft top with anti-static spray. Either that or make a stocking cap out of fabric softener sheets!
Old Oct 2, 2008 | 07:37 AM
steelerjeep's Avatar
The dryer sheet works I've had to do a couple time and as somebody posted leaves a nice smell. I usually put the one i use under the seat so its always there for the good smell
Old Oct 2, 2008 | 09:13 AM
Anglah's Avatar
From: Sitting on top of the world with my legs hanging free
Ditto, actually I leave a box under the seat and just take the top one out every once and a while.
Old Oct 2, 2008 | 09:20 AM
dyolfknip's Avatar
My roof leak takes care of static for me.
Old Oct 2, 2008 | 09:32 AM
thissideup's Avatar
Originally Posted by Strick
The temperature has dropped from 70-80º to low 50s in a week or so here in the Chicagoland region. The one thing I have really noticed is that my right forearm hair is standing on end due to the armrest. Anyone else having this issue? I mean I am sure it is pretty common, but man is it annoying. It is really really strong, BUT it hasn't zapped me or anything yet. Anyone getting zapped?
Shave your arms chewy!!!!! GURRRRRRRRRRRR
