View Poll Results: How is your Automatic transmission treating you?
I have NO problems, my transmission works great
85.24%
I am starting to have problems requring a visit to the dealer
9.84%
My transmission is a constant problem and has already been to the dealer
4.92%
Voters: 1199. You may not vote on this poll
Automatic JK Transmission Problems POLL
Old Oct 3, 2008 | 04:49 AM
  #121
badron5's Avatar
'07x no problems at 18k
Old Oct 3, 2008 | 05:49 AM
  #122
Greystn JK's Avatar
07 unlimited X with 42,000 K and I towed my 2800lbs. camper from Canada to Mexico without a hitch. Pardon the punn
Old Oct 3, 2008 | 08:15 PM
  #123
Greenmachine's Avatar
6K and no problems at all
Old Oct 3, 2008 | 08:42 PM
  #124
woody_k's Avatar
07 Stock X with 13,000 miles and no problem.
However when I start her up I put her in drive and wait about 15 to 30 seconds. The shifts are much smoother than if I were to start her up and take off. I get a little bump when going into 2nd gear the first time.
Old Oct 4, 2008 | 05:52 AM
  #125
Until2004's Avatar
Over 24,000 miles on the Jeep and no drivetrain problems at all.
Old Oct 4, 2008 | 09:49 AM
  #126
jcmrubicon's Avatar
Smile auto
20,000 and it still works great!
Old Oct 4, 2008 | 12:19 PM
  #127
Wrangle_on's Avatar
13,500 and all is well.
'07 Sahara
Old Oct 4, 2008 | 03:47 PM
  #128
ohlhockeyguy's Avatar
Almost 9k and no problems.
Old Oct 4, 2008 | 04:31 PM
  #129
JEEP4Dr's Avatar
I don't remember the milage but mine got stuck in second gear also. I ended up pulling over and completely shutting off the jeep and removed the key, put it back in and started it and it was fine. I called the dealer and took it in. No codes showed up but they reprogrammed it anyway. It was fine for awhile and we went out of town and Damed if it didn't happen again. It took several times shutting it off completely before it was ok. I again called the dealer and took it in. On the way to the dealer it started slipping really bad to where i drove it 10 miles per hr to get there. They did the reprogram again and said there was a code showing this time. So far it's been fine with 16,000 miles. I also had problems when i left the keys in it sitting in the garage it would be locked when we went to go. That happpened several times. Dealer said, Hey try the other key once and it's been fine since!! Figure that one out. I also had the brake problem that they recalled it for. Mine is an 07. Good luck to everyone with theres.
Old Oct 4, 2008 | 05:24 PM
  #130
jeepsanddrums's Avatar
Arond 9000 miles with no problems. I do plan on adding a cooler this winter.
