Automatic Trans Cooler
Old Apr 21, 2011 | 07:11 PM
cajunaviator's Avatar
Default Automatic Trans Cooler
A little curious here. I pulled my grill off today to do the mesh grill mod. I noticed a small cooler in front of my radiator that looks like a transmission cooler. My JK is an 07, has an auto trans and I have not added a trans cooler to it. I am also the original owner. Did the 07 JKs come with an auto trans cooler, or could they have been ordered with one installed from the factory. Someone special ordered my JK X with the Dana 44 rear axle, 4:10 gears and electronic disco.
Old Apr 21, 2011 | 07:13 PM
ronjenx's Avatar
How big is it?
The A/C condenser covers the radiator. The stock trans cooler is the bottom portion of it.
Old Apr 22, 2011 | 02:24 AM
cybersymes's Avatar
betting that's your air-con unit...
Old Apr 22, 2011 | 04:31 AM
It's just a little smaller than the radiator.
Old Apr 22, 2011 | 06:28 AM
ronjenx's Avatar
A/C condenser then. There will be two transmission cooler lines connected to it on the lower driver's side corner.
All automatic JKs have this. It's an inadequate cooler. It's a good idea to add an aux cooler.
Old Apr 22, 2011 | 08:27 AM
Yes both of the lines coming off of it say transmission. So what you are saying is that it is a trans cooler, but an inadequate one.
Old Apr 22, 2011 | 08:39 AM
ronjenx's Avatar
It is inadequate in a lot of situations. Overheating can be avoided if you have a transmission sump temp gauge.
Adding an aux cooler will almost eliminate the need to be so careful.
Old Apr 22, 2011 | 10:36 AM
Thanks for the info!!!
Old Apr 22, 2011 | 11:08 AM
Tuto's Avatar
A Picture will help .
Old Apr 25, 2011 | 06:40 AM
Thanks for the info Ronjenx. Didn't realize all autos came with one.
