Automatic transmission overheating redux
Old Feb 22, 2012 | 12:21 PM
Jiblet's Avatar
I strongly doubt Chrysler will do anything in the OP's case.
Not to sound critical but a change in driving style may be the fix.
A transmission temp gauge is a good idea along with an auxiliary cooler on most anybody's JK.
I'm not saying OP doesn't have an actual problem, like the galleries of his rig's stock cooler may be plugged or something like that. A temp gauge would give the info needed. In that, or similar case, I would hope the dealer figures it out.
Old Feb 22, 2012 | 08:16 PM
DesolationMania's Avatar
TY mp.
Jiblet, the snapshot read my tranny fluid at 202 degrees, which interestingly enough is still within normal. My only guess is in 2009 when they installed the hotoil illumination, they set it to go off if you even get near out of normal. But that is just my speculation. The dealer couldn't tell me what temp it's set to go off. I still have my own researching to do here. In the meantime, I will employ the advice I've gotten here as far as 4lo/OD off, etc.
Happy Wheelin'!
Old Feb 23, 2012 | 05:04 AM
Jiblet's Avatar
Originally Posted by DesolationMania
TY mp.
Happy Wheelin'!
202 isn't too bad but since it is heat that kill ATF, I hate to see it going up much over 200 for long. I was surprised how hot mine became just driving hilly terrain or in city traffic.
There are some nice multiple-function gauges out there that plug right into the OBDII port and will read out a lot of the parameters, codes, etc. including the trans temp.
I use an aeroforce interceptor. there are several choices in the market now. good stuff.
After I got the gauge and saw the trans temps, I couldn't get the aux cooler on fast enough.
Old Feb 23, 2012 | 04:30 PM
riorunner's Avatar
Default Trans cooler
Homguy, which model Derale did you install?
Thanks.
Old Feb 23, 2012 | 05:27 PM
ezav8tr's Avatar
Vet Army
I'm getting ready to pull a 1300lb trailer 1800 miles and am a little concerned. Will installing a transmission cooler outside of the dealership void my warrenty?
Old Feb 23, 2012 | 05:36 PM
ronjenx's Avatar
Only if the transmission fails, and it can be traced to a faulty cooler, or faulty cooler installation. (In a perfect world, anyway.)
Old Feb 23, 2012 | 05:54 PM
siggy14's Avatar
Is this an issue with the 2012 Jeeps? I just purchased an auto 2012 Sahara and just need to know if i need to get a cooler or not.
Old Feb 23, 2012 | 06:02 PM
ronjenx's Avatar
The 2012 automatics have a good factory cooler in front of the A/C condenser. Shouldn't be a problem.
Old Feb 23, 2012 | 06:03 PM
siggy14's Avatar
Thanks, good to know. Now to get it off road
Old Feb 23, 2012 | 06:06 PM
ronjenx's Avatar
Even with the better 2012 cooler, I recommend a gauge that will read transmission temp from the obd II connector.
