Automatic transmission question
Old Apr 10, 2016 | 02:52 PM
ronjenx's Avatar
Originally Posted by WEIMWGN
Oh, ok.....I thought that normal operating temps, the fluid had to be between the two top holes.
Depends on what is normal.
Mine normally runs between 90°F and 130°F.
Old Apr 10, 2016 | 06:54 PM
WEIMWGN's Avatar
5 Year Member
Loved
Thanks for the info and the help!
Old Apr 14, 2016 | 12:23 PM
WEIMWGN's Avatar
5 Year Member
Loved
Turns out that I have a transmission cooler which explains the extra tranny fluid.
Old Apr 14, 2016 | 05:59 PM
Spytec128's Avatar
Veteran: Navy
My factory repair manual for the 2007 says the normal operating temperature is 180 degrees F. Should take about 15 minutes of driving. I just changed mine last weekend and used 5 and 1/2 quarts so 6 is about right. The repair manual also says check at normal operating temp, on level surface, and in park after running through all the gears first stopping for a couple seconds in each gear.
Old Apr 14, 2016 | 06:52 PM
ronjenx's Avatar
That doesn't mean it will normally be at 180°F. It just means it's OK to be at that temperature. It's probably a carryover spec from when the transmission fluid was routed through the engine's radiator.
