axel question
Old Apr 12, 2007 | 03:49 PM
formentojohn's Avatar
Default axel question
I have the wrangler x do I have the dana 35?
Old Apr 12, 2007 | 04:12 PM
yellowjeeper85's Avatar
Unless you have the tow package, the four door, or the rubi, it comes with a Dana 35, being that you have the X, i would assume you have the Dana 35. If you look under your rear end, and see that the axle cover is oval shaped, then you do indeed have the dana 35 rear axle. I hope that helps.
Old Apr 12, 2007 | 04:41 PM
fattygio's Avatar
The X JK 2dr has the Dana 44 in the read, dana 30 in the front
Old Apr 12, 2007 | 07:41 PM
yes it helped thanks
Old Apr 12, 2007 | 08:19 PM
I'm not trying to pick any fights, or tell you that you're wrong, but the 2 dr JK X has the Dana 35 in the rear unless you got the tow package or specifically ordered the dana 44 somehow. Stock, the X 2dr comes with the Dana 35 in the rear, but you are right about the front, as the X JK 2 dr or 4 dr or tow package or not has the dana 30 in the front
Old Apr 12, 2007 | 11:01 PM
dougr5150's Avatar
I think this was only for the first few production units, I have a 2dr X with a build date of 10/1 and I have the 44 in the rear. When I first got mine I asked this question and got into a lot of arguments because all the info said 30/35 but no one could prove it to me with a picture except a couple of the vendors that had pre-production models. I can not say for sure that they all have 44 in the rear but it sure seems to be that way, but if anyone with a build date after 10/1 with a d35 in the rear please speak up.
Old Apr 13, 2007 | 05:34 AM
IGOFSHN's Avatar
Looking at the Jeep website, it says D35 unless upgraded, so they are still out there.
Old Apr 13, 2007 | 07:55 AM
IGOFSHN's Avatar
Originally Posted by Mr. T
OK. even though the web is saying that it is with the Next Generation D35, unless with towing on the X, i decided to do a little homework. Well, actually, curiosity drove to snoop around.
I have tow hooks, but, not the "tow package" which they say will upgrade you to the D44, but, decided to call the dealer after not finding info online anywhere. I found out that i do indeed have a Next Generation Dana 44 "heavy duty".
If you are unsure, you can call the parts department of your local dealer and give them the last 9-digits of your VIN, and they will tell you.
Either way, I have an X with the S package, 2-dr, 6-spd with the D30 front and D44 rear.
That is definately the best way to find out.
Old Apr 13, 2007 | 08:46 AM
fattygio's Avatar
My 2 dr has dana 30 in the front and dana 44 in the read, I do not have the tow package... jeep.ca... dana 44 standard...
Build date is Nov 9, 06
2dr JK X Wrangler base model
Old Apr 13, 2007 | 08:48 AM
fattygio's Avatar
Axle – Next-Generation Dana 35 solid rear (included with automatic transmission) P P P
– Next-Generation Dana 44 heavy-duty solid rear (included with manual transmission)
This is from the Jeep website....
