View Poll Results: Has your axel seal failed? Take the freaking poll!
Yes one has!
190
39.09%
Both failed!
50
10.29%
No, nothing yet.
235
48.35%
Whats an axel seal?
11
2.26%
Voters: 486. You may not vote on this poll
Axel seal problem poll.
No axle seals leaking @ 80,000 miles. I've had both front shafts out for ball joint change. No leaks after reinstalling the shafts.
But then, I took precautions when the front shafts were out:
Cleaned the axle tubes
Cleaned the shaft splines and the areas the seals ride on, then applied some grease
Made sure the plastic discs were in the proper place on the shafts to ensure alignment through the seals
As an added precaution, I have the oil level in the differentials high enough to keep the seals wet.
This has worked on two JKs I have changed the ball joints on.
