axle lock????
Old May 14, 2007 | 03:19 PM
Ddealer's Avatar
Default axle lock????
sorry I'm a noob at 4x4...
i got a question... but can some one tell me if it;s ok to drive with your rear axle locked? and is so what are the pros and cons? and should i do it often? and is it ok for the JEEP?
ty for the answers
Old May 14, 2007 | 03:20 PM
bodybrdng's Avatar
ty for the answers
you should never drive speeds above 15mph with your axle locked
Old May 14, 2007 | 04:19 PM
IGOFSHN's Avatar
So what if you have an automatic locker????? It is locked at highway speeds????
Old May 14, 2007 | 04:24 PM
bodybrdng's Avatar
no it will only lock when need
Old May 14, 2007 | 05:04 PM
Ddealer's Avatar
Default yes
on the highway yes,,, around 60 mph? had the rear locked?
what is the lock for???
Old May 14, 2007 | 05:16 PM
Renegade's Avatar
From what I understand, factory electric lockers (if you have them) will only lock when 4wd is engaged and you are travelling under 18 mph. Hopefully you aren't running 4wd on the highway. If you are, it's not the locker you should be worried about... Lockers are for engaging both wheels of an axle for maximum traction while off road.
Old May 14, 2007 | 06:01 PM
4EverLSU's Avatar
The pros are only when you are in 4WD, and only under 15mph. It keeps both wheels spinning independent of the other. Without a locker, if one wheel is in the air, the differential is going to give most power to the wheel without traction...and none to the wheel on the ground. With a locker, both wheels spin at the same time.
There are nothing but cons if you are on the highway. If you're running axles locked, tehspecially on pavement...you can kiss your differential good bye. During high(er) speed turns, each wheel needs to spin at a different RPM to attain the same speed. If you force them to turn at the same speed, you are going to eat up gears, and most likely shear a shaft in your axle. That tends to bring Teh Suck.
Old May 14, 2007 | 06:35 PM
IGOFSHN's Avatar
Not true. A detroit is locked all the time except when turning. Locked any other time.
Old May 14, 2007 | 06:37 PM
IGOFSHN's Avatar
People run spools and mini spools all the time on the street. The only thing that get eaten up are the tire.
Old May 15, 2007 | 03:09 AM
Renegade's Avatar
But this won't happen, because you CAN't lock stock lockers when travelling over 15 or 18 mph.
