Axles-- 3.21 or 4.10?
Is there a big difference in axles-3.21 4.10?
If I order the towing package it changes the axle ratio. If I put an aftermarket hitch on, the I could get the 6 speed with the 3.21. Any Comments? Thanks |
Originally Posted by Heyspike
(Post 4432)
(Post 4432)
Originally Posted by Cadually
(Post 4434)
3.21 is standard with manual or auto.
Originally Posted by mmccurdy
(Post 4436)
If you go auto, I'm pretty sure you have no choice but the 4.1.
I have a Shara unlimitd 6-speed with the dana 44 rear lock, it was a option but no tow pkg. Is the rear end on the dana 44 still a 3.2 or do they change it to 4.10?
I like the 4.10's in my D44! Yeah first and second are both a bit short, but in the snow it makes for a good 2nd gear start. Plus it really does take off when I shift just right.
Scrambler |
i like the 4.10 in mine a little more pep, i have the auto. plus if you ever decide on running bigger tires the 4.10 will help out.
Originally Posted by Jazzdshaw
(Post 4675)
The only towing I usually do is a lawn trailer about once or twice a week. If the milage was a big difference, then I would do the aftermarket hitch, but if it's not that bad--4:10's it is.
Thanks |
