Axles
Old Jul 20, 2009 | 02:36 PM
JKinLB's Avatar
Default Axles
What is an "anti-spin" differential? I just got my build sheet, and that's what it says my rear axle has.
Old Jul 20, 2009 | 02:48 PM
joes's Avatar
It's what happens when your drive shaft breaks
Old Jul 20, 2009 | 02:57 PM
JKinLB's Avatar
So, does that provide me any traction benfits while wheeling? Been lamenting my lack of lockers.
JKinLB's Avatar
Pipe down, Chachi!
Old Jul 20, 2009 | 03:04 PM
JKinLB's Avatar
Originally Posted by GoodysGotaCuda
Yes, it does. It is between a locker and open differential. If you get a rear wheel off the ground it will more or less act like an open differential. For general both wheels on the ground it will provide power to both wheels pretty well, not 100% like a locker...but not bad by any means.
Thanks! The info is much appreciated!
Old Jul 20, 2009 | 06:44 PM
JKinLB's Avatar
So, another question...are limited-slip diffs the norm on non-Rubi JK's? I mean, do some of them come with fully open diffs?
Old Jul 20, 2009 | 07:06 PM
cyruspura's Avatar
Some X's and Sahara's come with a rear limited-slip differential. This is a pseudo-locker that senses a loss of traction and activates to compensate.
My understanding is that all JK's also come with what's called a "brake-lock differential". So far, I've had no problems with traction in my unlocked X. See below for more on the BLD...
"Available for the first time with Jeep Wrangler models are Brake Lock Differentials (BLDs), which are incorporated into the Electronic Stability Program (ESP) algorithm. BLDs apply braking force to an axle's spinning wheel in order to provide an equal amount of torque to each wheel and deliver greater traction for rock-crawling over severe off-road terrain. A separate set of BLD calibrations is designed for off-road operation and automatically activates when driving in 4 Low."
Old Jul 20, 2009 | 07:17 PM
JKinLB's Avatar
Thanks, cyrus!
