Ball joint install
It's only been an hour, relax a bit. Anything is possible.
Did you put it in with the ball joint tool? No reason it can't come out that way. If you have to get creative and use sockets then go for it.
Sent from my DROID4
Sent from my DROID4
I just replaced mine last weekend. By the marks on the new ball joints you attempted using washers or something similar as spacers. I started my uppers the same way and they started to go in crooked, so I stopped and pushed them out before they were all the way in. IMO, the write ups that use only the loaner ball joint press that you get at he auto part store are only going to lead to problems. I went out and got a ball joint master adapter kit, and it made everything a million times easier. I know it will cost some coin, but do yourself a favor. I got my kit at Harbor Freight for $70.
But to answer your question about taking them out and reinstalling, I don't know. There are splines on there that help hold them in place when you press them in. If you push them back out, those splines will no longer be there to do their job. I just don't know if I'd take that chance. you may need to get in touch with a liscenced mechanic to see what they recommend.
