Ball joints testing
Was testing my ball joints this afternoon with a pry bar and my driver side got more play than me passenger side, what is the maximum up and down play acceptable on front C ball joints ?
Also I was feeling a little knock while doing the up and down test on my driver side normal or not ?
Thanks
P.S before telling me to use the search feature give it a try your self
Thanks
Here is some info related to both questions:
Radial (side-to-side) movement in the upper ball joint should not exceed 0.060" (1.5mm).
Axial (up and down) movement in the lower ball joint should not exceed 0.050" (1.25mm).
A dial indicator is the best instrument to measure ball joint play.
Jack the front tire off the ground.
Place a jack stand under the axle next to the jack.
Lower to put some weight on the jack stand.
Place a long pry bar under the tire, from the side.
Have someone pry the tire up and down while you watch the lower ball joint for up and down play.
Have someone grab the tire at top and bottom to wiggle the top in and out while you watch the upper joint for side play.
Even if the upper joint checks good, change both if the lower checks bad.
