Bank 1 Sensor 1 Loaction?
Those componants would only be Can bus components as it verifys serial numbers for theft and warranty tampered items on the can bus. I have changed throttle body, cam sensors, all 4 cam solenoids and map sensor with no programming. Pcm can however record some componant disconnects also as a tamper proofing for warranty also.
So, I wonder what it is about the cam system that makes the engineers think it needs a Cam Variation Relearn procedure, when practical experience indicates otherwise. Could it be most of the time just installing the components is close enough, but not spot on?
The throttle body and MAP sensor show no requirement for a reprogram/relearn upon replacement.
I could be way off mark and completely wrong but i do know for a fact some sensors report a log of disconnects and stores them for technician use.
Originally Posted by scooby snacks
Let me know how it turns out... Interested in the effort!!
So far all good. Thanks for the quick response.
Originally Posted by ronjenx
Did you get a code?
If so, have you eliminated other possible causes before condemning the sensor?
According to the service manual, when a sensor is replaced, there is a Cam Variation Relearn procedure that must be performed using the dealer's scan tool.
Each cylinder head, (bank 1 on the right side, and bank 2 on the left side), has two camshafts, with a camshaft position sensor, (CMP), between them, on the top rear of the cylinder head cover. The sensor has two circuits in it, making it capable of monitoring both camshafts.
The exhaust side of each sensor is position 1, and the intake side of each sensor is position 2.
CMP Sensor 1/1 is the exhaust side of the sensor in the right head.
