Battery replacement
#42
Also, you may want to tame down the "Ohm's Law" lecture when you're speaking with an Electrical Engineer who is well versed in Ohm's Law, Kirchoff's Current Law, and "Watts law" and has quite a bit of experience in applying them since the law you're actually attempting to lecture on is "Watts Law" and NOT "Ohm's Law".
Have a good day.
#43
We're just talking about 2 different options. You decided to go with a dual battery setup using 2 of the more cost effective Deka batteries. I decided to go with a higher performance, yet more expensive battery for a similar end goal because I didn't want a dual battery setup. I didn't feel purchasing 2 separate batteries at half the cost, and additionally spending another $480 on top of that really points itself to a good value setup but if it works for you, that's fine. A single higher cost, higher performance battery with a simpler mod path works better for me and if I was worried I would run into a situation where I found myself often draining my battery during winching, then I could just purchase a battery pack.
When I looked at the Genesis dual battery setup there were a lot of holes I could punch in this story they have shown.
What that diagram doesn't show is the 3rd power source which is the alternator. Their intended use seems to be....drain the AUX battery at some camping outing without your vehicle running, and the setup will protect you from running down the starter battery while you're doing that. However, notice in their diagram they don't show that 3rd power source and what happens when the vehicle is running, while you're running your accessories. I can draw that total circuit diagram up, analyze it and punch holes in that scenario since the alternator is directly tied to the starter battery.
So let me start with one of those questions to think about. They say "when" the "Main"/starter battery reaches 12.7 volts, it will isolate the Main battery from the Aux battery, so that your accessories don't continue to drain the Main starter battery. Ok...sounds great. What is it doing when the vehicle is running and the alternator is put in parallel with that Main battery and the alternator is now putting out 14 Volts? It's not switching off of that main battery if the main battery is actually sitting at 12.7 Volts now is it? The Main battery will now be sitting at 14 Volts due to the alternator running. So how much are you really isolating your main starter battery now that it is connected in parallel with that 3rd power source, which is the alternator?
Notice how they say in that diagram, "After 2 minutes" of the Main battery measuring above 13.2 Volts, it will connect the Main and Aux together. Well hello? They're not really measuring the voltage of the main battery in that scenario. They're measureing the voltage of the alternating and are just setting a 2 minute timer where the only thing they know when they connect the batteries back together is that your Jeep has been running for 2 minutes, because the Alternator raised the voltage above 13.2Volts.
#44
Look, I stated this earlier. The Odyssey battery weighs 10 more lbs than the same size Deka battery. That's 10 more lbs of internal battery material compressed into the same Group size 34 package. That's the reason the Odyssey battery out performs the Deka battery. It's no secret that more material=more power when it comes to batteries. That's the reason the Odyssey battery has higher RC and CCA specs than the Deka battery of the exact same group size and that's a significant reason why it costs more as well. Look at the weight of the Northstar batteries I also posted. It's the same story.
#45
I can see how that can be confusing, according to Genesis and your diagram from them even if the engine is running the smart isolator will disconnect if the main voltage drops under 12.7, now in a winching operation this could happen multiple times connecting and disconnecting the main so it doesn't affect other systems on the main battery and it lets the aux battery be used to it full potential.
