Sponsored by:
Sponsored by: DashLynx
Bent Brackets on Front Axle - Straighten??
Old 10-04-2010, 06:46 AM
gearhead9's Avatar
Default Bent Brackets on Front Axle - Straighten??
I bought a used 2009 Unlimited X, the driver side lower control arm bracket on the front axle is smushed down and tweaked inward, any suggestions on how to straighten?, should I be concerned with metal fatigue and the bracket not holding up?
Old 10-04-2010, 05:39 PM
gearhead9's Avatar
Originally Posted by GoodysGotaCuda
You should straighten and gusset it, or cut them off and weld stronger ones on.
-do I have to worry about heat on the axle tube?
Old 10-04-2010, 06:01 PM
Fly-Attack's Avatar
Only slightly.....I would just straighten and maybe reinforce depending on how much you have to move it back to a normal position. If you have to weld just do it in small 1" beads and allow it to cool.
Old 10-04-2010, 07:03 PM
rmdchewie's Avatar
At this point you should cut it off and replace them with after market mounts. Plenty of places sell lower mounts made with 1/4" steel that you'll never have a problem with again and they're not expensive. Also no worries with the heat on the axle tube.
Old 10-05-2010, 05:25 PM
gearhead9's Avatar
Default thanks alot for the advice
I"ll try it this weekend
Quick Reply: Bent Brackets on Front Axle - Straighten??
