Brake calipers
Old Jan 21, 2016 | 08:13 PM
aro's Avatar
aro
Default Brake calipers
I'm putting back the rear brake calipers and they don't quite slide on the rotor. Is there any trick I can use to make them slide, or do I have to remove that upper bolt with the rubber boot, open it up, remove pads and then push the piston back? I'm probably within a thou of an inch.
Old Jan 22, 2016 | 03:29 AM
BrowniesJK's Avatar
Use a brake spreader or a "c" clamp. I always use the "C" clamp. Pull pads and push the cylinder in.
Old Jan 22, 2016 | 04:30 AM
aro's Avatar
aro
I was trying to avoid opening up the caliper adapter, but I guess I have no choice. There isn't enough room between the pads to pull them out without opening up the caliper.
Old Jan 22, 2016 | 09:14 AM
busa250's Avatar
Prolly took longer to post this than removing the caliper. Lol. I changed all four rotors and pads plus painted them black in four hours on my liberty.
