Brakes hold sometimes
Old 12-20-2013 | 04:39 AM
offroadtimmy's Avatar
Default Brakes hold sometimes
I have a 2010 rubicon unlimited 6 speed and sometimes when I leave from a stop, I feel the brakes hanging up. Is this normal?
Old 12-20-2013 | 04:50 AM
Lorrel's Avatar
pretty hard to answer as hanging up to you may not feel like it to others, With disc brakes the pads always are somewhat against the rotor.
I would lift the vehicle off the ground and simply rotate the tires by hand. If a brake is hanging up you should be able to feel the difference.
Old 12-20-2013 | 04:53 AM
Cjsmith4's Avatar
are you sure this is not the hill hold assist kicking in? I have heard about this same problem before but not sure what year Jeep started using the hill hold assist. Anyone else think it could be that?
People have even said its bad enough where they would stall when they were first trying to pull out because it felt like the brakes were holding them back. If it is the hill hold assist, you can turn it off.
Old 12-20-2013 | 06:47 PM
That is exactly what it feels like. I just got the jeep 1000 miles ago and stalled it twice because of this. Do you know how to turn it off?
Old 12-20-2013 | 06:52 PM
karls's Avatar
It pops right up on google with "turn HSA off jk" but there's a link below since I couldn't find it in the manual.
http://wrjeepclub.com/simplemachines...p?topic=1399.0
It's a nice feature but sometime obtrusive, you've got to learn to time it then tap the gas if you leave it active.
Sent from my DROID4 using Tapatalk
Old 12-20-2013 | 07:07 PM
Originally Posted by karls
It pops right up on google with "turn HSA off jk" but there's a link below since I couldn't find it in the manual. http://wrjeepclub.com/simplemachines...p?topic=1399.0 It's a nice feature but sometime obtrusive, you've got to learn to time it then tap the gas if you leave it active. Sent from my DROID4 using Tapatalk
I will try it. Thanks for the help
Quick Reply: Brakes hold sometimes
