Broken swaybar bracket
Old 12-10-2016, 09:55 AM
m2736185's Avatar
Default Broken swaybar bracket
When I purchased my jeep it came with one of the swaybar bracket bolts broken in the frame. I was driving offroad and heard a pop. When I came out to inspect the swaybar bracket on the passenger side completely broke off and now the sway bar is pushing against my drive side frame. I am going to just disconnect it for now. Is there a relocated bracket on the market so I can mount the swaybar bracket elsewhere? The threads for the old mounting location is no longer good.
Old 12-10-2016, 07:11 PM
karls10jk's Avatar
To correct that you should cut and tap the holes for the next largest bolt you can get in there and put a nut on it.
Alternatively- teraflex will sell you a sweet dual rate sway bar with all of the fixings to get rid of what you've got. Someone else makes one as well but the name escapes me right now.
You may want to add some sway bar disconnects to this bar.
Old 12-10-2016, 07:36 PM
m2736185's Avatar
how would I get a nut inside the frame horn? Maybe just use an impact driver and put some lag bolts in there? I checked out the Teraflex sway....$800 thats pretty pricey for a sway bar
Old 12-10-2016, 07:47 PM
karls10jk's Avatar
I forgot about the frame horns, I'm used to the previous model where it was open. It is a pricey option, the tera, but aside from extraction, cleaning the threads, and trying your luck again I'm not sure what to suggest. Maybe someone else will have an idea on how to fish a nut to the front for you.
Old 12-11-2016, 12:44 PM
Rebar-7's Avatar
Well aside from drilling and trying to re tap it, you could just have the mount welded to frame. Or replace with Currie Antirock swaybar to the tune of $480
Quick Reply: Broken swaybar bracket
