Can I remove the front driveshaft for long travel.
Would this be ok?
I remember someone saying you "have to have it so the oil would work". Is this just crazy talk?
I'm thinking about a long roadtrip and thought it might save on mileage (and breaking a transfer case).
Anyone know for sure?
Would this help my mileage?
Thanks
Thanks
Would this be ok?
I remember someone onetime saying you had to have it so the oil would work. Is this just crazy talk?
Thanks
Thanks
anything. when you put it in 4wd the transfer case is still going to engage the same as it would it just wont be transferring the power to the front without a driveshaft.
It won't hurt anything there is just no point to doing it. I had a buddy blow up his front differential so he pulled the driveshaft so he could keep it on the road. It drove perfectly normal minus the fact he no longer had 4wd haha.
I seem to have this same setup here.
It's pretty easy to remove the aftermarket driveshaft. It's only 4 bolts each side.
I've seen others with this setup bust their transfer case also.
Whach think?
Whach think?
Whach think?
Whach think?
You have nothing to worry about unless you have a steep driveshaft angle or are experiencing any vibrations. The t cases are not just spontaneously exploding its a result of excess stress. But with all that said if you are more comfortable doing the trip without the driveshaft installed by all means there should be no reason why you cannot remove it as I mentioned I knew a buddy that drove a truck for months without a front driveshaft.
The differential/axle shafts spin anytime the front tires rotate. Being in 2wd doesn't stop this.
With it in, the engine would be pushing the front, turning the driveshaft, and turning the t-case. would this not make any sense to do?
Thanks
