Can the trailer software be added on my 2014?
I have a 2014 Willys Wheeler with the 3.73 gears and no factory towing package.
I want to add the Rugged Ridge hitch assembly and 7 pin round male plug to match my 4x8 1000 lb GVW utility trailer that I use for kids ATV and dirt bike hauling.
If I go to the dealer, can I get that trailer sway control software added, or is it only supplied at the factory level off you paid for the trailer package?
I have a 2014 Willys Wheeler with the 3.73 gears and no factory towing package. I want to add the Rugged Ridge hitch assembly and 7 pin round male plug to match my 4x8 1000 lb GVW utility trailer that I use for kids ATV and dirt bike hauling. If I go to the dealer, can I get that trailer sway control software added, or is it only supplied at the factory level off you paid for the trailer package?
Either way, my 12 didn't have tow package, so I bought a hitch from Quadratec and harness from them too. Pull a 1800lb max trailer that is 4x8 quite a bit and I pull a BassCat Jaguar every weekend. My jeep has 35's and 3.73's. It's a struggle with the boat at 70mph but it is fine at slower speeds. Even in crosswinds it's pretty stable. Only thing is suggest is trailer brakes. Real ones, not inertia brakes.
My understanding from threads I followed 2 yrs ago is that the anti sway software can only be configured in the factory when the jeep is being built. Having said that, I don't think you will need it if you load the trailer properly. More weight in front of the axle and less behind the axle. I also agree with "real" trailer brakes. My 3500 pound toyhauler has dual axle trailer brakes and I am very pleased with how it tows and stops.
When I was checking into the purchase of my JKUR, I specifically asked about the tow package software.
What the sales guy told me was that the algorithm for the towing stability control was essentially the opposite of that used without a trailer. It sorta makes sense when you think about it because a trailer that's getting away from you will push the vehicle in a way that is different from if you were just losing traction. But what I can't figure out is how the computer would know that it's a trailer traction control situation versus just losing it with no trailer.
When I was checking into the purchase of my JKUR, I specifically asked about the tow package software. What the sales guy told me was that the algorithm for the towing stability control was essentially the opposite of that used without a trailer. It sorta makes sense when you think about it because a trailer that's getting away from you will push the vehicle in a way that is different from if you were just losing traction. But what I can't figure out is how the computer would know that it's a trailer traction control situation versus just losing it with no trailer.
Well, I got the Rugged Ridge frame hitch and wire harness installed yesterday. It was a 30 minute job, very easy and perfect fit and it was only $60 from Amazon. Next weekend we go camping, that will be the first time pulling the little 4x8 trailer.
Huh? Can yo be more clear? In my experience, you need more weight in front of the trailer axle than you have behind the trailer axle. Not sure how your 30% number jives with this.
