Can't figure out how to replace drivers headlight bulb
Apparently my 2010 JKU has me beat. Can anyone tell me how to get the old bulb out? Do I have to remove something to allow room to get it out?
Thanks
Thanks
U gotta pull the grill off. 5 plastic clips on top as soon as u open the hood, pull them out then u can pull the grill forward to remove it from the other push clips. There are 4 small torque bolts around the headlight take them out and the headlight will pop right out. Reverse process to install.
Sent from my obama monitoring device
On my 08 driver side just remove the horn on passenger side remove air box and the bolt to the power steering fluid container thingy.I just did my passenger side took 10min tops. Good luck
If you have done all of the above steps, PLEASE PLEASE PLEASE remember before the bulb will separate from the carrier there is a small lever that has to be lifted before then bulb can be pulled out. If you would like I can take pictures. Hope all this helps.
