Changing the brake fluid
My local mechanic is telling me my brake fluid is bad. I'm thinking he might be right. The fluid looks pretty dark and smells kinda funny.
The thing is, I'm not sure how much oil it's going to take. I'm pretty sure the clutch and brakes share the same system, right? So, would this be something my local mech. can do or is it something I need to take to the Chrysler service center? (which, I might add, is a real PITA over here in Korea)
Thanks,
Tony
Thanks,
Tony
They do NOT share the same oil. You need brake fluid. Any service center should be able to flush the brake fluid. You might want to stick with a good brake shop.
The right thing to do, especially with newer ABS systems, is to change the fluid every two years, whether it looks like it needs it or not. It's easy to do, and will avoid corrosion problems in the future.
Easiest way is to use a suction device - like a Pneumatic Brake Fluid Extractor
That will just suck the fluid out through each caliper with clean-fluid filling in behind it.
Can you gravity-flush an ABS equipped system? I've never tried.
